no furnace fan??
Lube plate for fifth wheel
Satellite Antenna
JSzewczyk
Had a problem this weekend at the Martinsville race. We set the heater on and went to bed. In the morning i had dead batteries. while charging the batteries the next day, I dicovered that my furnace would trun on, light up up but had no fan blowing. The exhaust was coming out rather hot, but I was not getting any flow out of the registers. THe fan switch on the thermostat did not make a difference either. I moved the switch from high to low but it made no difference. I took the cover off looking for a loose wire or other simple fix. I also checked out the thermostat's wring and it was all good. Anybody have any thoughts?
If this is in a camper there is some sort of temp control that turns the fan on when the furnace gets hot. No power thru that, no fan. Might want to gram a meter and the wiring diagram and chek your power route. could be a bad fan motor, if it is the motor would likely be hot as hell after a minute or two of the t stat calling for the fan and it not running.
Take of the front cover and look through the exhaust for a bug nest, also check for a bad sail switch. You may have to do a little more disassembly to really check it out but it's not hard to do.
The fan & sail sw. have to work to turn on the gas valve & ingniter , if its lighting up then I would think that the curcuit board is bad .
I had a hornets nest in mine this fall , I saw them going in & out last summer , so I put a pice of metal screen under to outside exhaust , but it was too late , they had built a nest in by the sail & it keeped the furnace from turning on .
Screens can get clogged with dirt and debris, they tell you not to use them to absolve them from any liability. Its all about liability.
