About 2 weeks ago I had the dealer do the EGR valve and cooler service (live in NY and its on them). 2 days ago on the drive to work I noticed I wasn't getting any heat. When I got to work I saw a little steam coming from hood. Popped the hood and saw the reservoir was empty and there was evidence of coolant on the engine in the area of the reservoir. After work, I filled the reservoir and drove home. No heat on the way home but the reservoir was still full. The truck didn't overheat. The temp gauge fluctuated (more then usual) around 200. I got under the truck and saw evidence of coolant sprayed over the undercarriage, to the rear of the engine. I read other posts that indicate the water pump can go and leak through the weep hole but the front of the engine is bone dry, including the water pump area (assuming I am looking at the water pump). The wet area seems to be back toward the reservoir and underneath behind the engine. Any ideas? Thanks in advance.
Kevin
Kevin
