Are the two coolant lines going into your fire wall to the heater core both hot? If not, you might have an issue with a blockage! I've been batteling low heat, and this was one thing I checked. I dont know if the 12 valve motor's are the same heat set up as the 24, but you can disconect those two hoses and flush them with a garden hose carefully to try and dislodge anything that might been blocking it. I used a barbed hose connector and hose clamped it to the inlet hose, and then the outlet hose, flushing in both direction's. I wouldn't run the hose all the way open. Just enough to get a good flow to see if it's blocked. You might want to check the Thermostat also! I don't know if any of this help's, just thought I'd give some suggestion's! Good Luck!!
