Hi Guys, just purchased an 89 to fix up for my son, who is overseas in the desert defending our freedom. Problem one. Turn key to 'on' position and no wait to start light. Checked solenoids under hood and no power to the small wires. Where should I start?
Problem two. Previous owner claimed it was HARD starting lately and smoked the starter after installing a new lift pump. So I installed new starter, cause the old one was smoked,not just the contacts, bled the injector lines and she ran like a million bucks. Way better than my 24 valves. Anyhow shut it off, wait 30 minutes and no start, bleed lines, fires up, wait 30 minutes and repeat. I found the WIF sensor leaking on bottom of filter, so I changed it out with a sensorless filter. Still same problem. An old 12 valve nieghbor of mine says it's a problem in the fuel tank, bad pick up? I dunno.....
Thought I'd querry the experts before I rip the fuel system apart and reseal everything.
Thanks
Mike
Thanks
Mike
