2nd Gen Non-Engine/Transmission No Lic. plate light
Engine/Transmission (1998.5 - 2002) Deer vs Dodge
2nd Gen Non-Engine/Transmission Sticking emergency brake cable
LHastings
Got pulled over this morning for no lic plate light. Does anybody know what the bulb number is and is there a fuse for this light.
Best bet is pul the lamp and go to a parts place for replacement. If you're as "lucky" as I've been (not) you may find the sockets are melted to the point of requiring replacement. Presently I'm on a set of sockets purchased about 6 mos ago and one is totally melted. I'm trying to locate a replacement socket that isn't a POS - wish me luck.
I put in 1998 for your truck... great web site!
http://www.sylvania.com/ConsumerProducts/AutomotiveLighting/LampReplacementGuide/AutoLRG-Results.htm
Auto Lamp Replacement Guide - Results
Print out the list and find them at your nearest retailer.
1998 DODGE Ram Pickup
High & low beam headlamp
9004LL
9004SU Silverstar ULTRA for Ultra Night Vision - The Whitest and Brightest Halogen
9004ST Silverstar High Performance Lighting: The Whiter and Brighter Halogen
9004XV XtraVision Halogen - The Brighter Light
9004CB Cool Blue Halogen - The Whiter Light
Parking light
3157A
3157AST Silverstar Signal Lighting: Complete the Look: Crisp, Clean, Style
3157NALL Long Life Upgrade: Up to twice the life of the standard lamp
Front turn signal
3157A
Rear turn signal
1157
1157LL Long Life Upgrade: Up to twice the life of the standard lamp
3157
3157LL Long Life Upgrade: Up to twice the life of the standard lamp
Tail light
1157
3157
Stop light
1157
3157
High mount stop light
921
921LL Long Life Upgrade: Up to twice the life of the standard lamp
Fog/Driving light
893
893ST Silverstar High Performance Lighting: The Whiter and Brighter Halogen
License plate
1155
168
168LL Long Life Upgrade: Up to twice the life of the standard lamp
Back up light
1156
1156LL Long Life Upgrade: Up to twice the life of the standard lamp
3157
3157
Front sidemarker
3157A
Rear sidemarker
194
194LL Long Life Upgrade: Up to twice the life of the standard lamp
Ash tray
161
Glove box
1891
Dome light
579
Step/Courtesy light
194
Trunk/Cargo area
921
Under hood light
561
Instrument-general
158
PC194
PC74
Check engine indicator
PC74
Hi-beam indicator
PC194
Seat belt indicator
PC74
Brake warning
PC194
Automatic transmission indicator
PC74
Directional signal indicator
PC194
Ignition switch
1445
One of my lic. plate light assembly fell out of the bumber and was hanging loose behind bumber light still on. I did a little afro-engineering and got put back where it belonged. (The heat from the light melted something ,don't remember what it was)
SSolderitch
Thanks for the search i got the bulbs out and they are 168 I'm going to the parts store now and see I can find the long life bulbs.
You will find the 161 bulb has the same base configuration and has a total current draw of only 180 mills. This will keep you out of johnny-laws eyes and allow your socket to last longer. The original bulb draws 330 mills and will cook-out the socket. A lower current draw will naturally last much longer. (It's the ashtray bulb)
Good luck
William
