I am working on a 96 2wd also for the same problem. I have tapped into the brown (overdrive wire at the pcm) and the orange (lockup ) wire and found that the 12vdc drops out when the od is suppose to shift, I do get the 500rmp change but no OD. I am wondering if the coil could be shorted and still pass the 12v back to the PCM or does anyone know what the OHMs is suppose to be. I am going to try to do a pressure test asap ( soon as I can get on my lift, got to finish another round to it first), to see if I have the right pressure for the OD to engage. I want to check the coils before I pull the pan so I will know if I need to buy a coil pack, it would be nice to have onhand to save down time, if it is needed.
Thanks,
Dieseltim
