UPDATE: Drove the truck about 40 miles this afternoon and observed the following. Start cold, pressure reads around 60. Steadily drops below 40 and will not read above 40 again until another cold start regardless of engine speed. I stopped by the dealer, the mechanic let me install the test gauge after he burned his fingers a few times. I installed it on top of the oil filter housing at the 1/8 inch npt fitting. Dash reads about 20 psi when the Snap-On mechanical gauge says 21 at idle in gear. When I rev the engine, pressure goes to 40-70+ almost instantly on the test gauge and only gets to about 39ish on the dash gauge. When the gauge slowly drops down to about 21 indicated, it suddenly drops to 0 like I turned the key off , lights the check gauges and dings. This happens almost every time I let off the gas and the engine returns to idle speed (in gear) when the motor/oil is hot. When in neutral, does not happen. I have guessed that the factory ECM program for the oil pressure gauge drops to 0 when it sees 20 or less psi? I have a virgin 2000 auto ECM. Dealer suggested a new pressure sender at $200 for the part. Going to call Cummins parts counter tomorrow and ceck price. Anyone an expert on this subject or had a similar experience?
FYI, oil pump is about $192 @ Cummins (Cummins PN 393 7404 at least for my engine SN) and almost FOUR hundred at the DC parts counter. . Parts guy said he doubts an oil pump as do I.
