First off about a 1 1/2 years ago I put a new oil pressure sensor in my 99 and had the computer flashed to accept the new updated sensor!!!!! Not long about 8 months later the oil pressure gauge started messing up. Like I was losing oil pressure, but then it would come right back on. Almost like you you'd cut the power and then give it back. It would do that awhile then it would work for the rest of the day. Then after a few months of that it decided it didn't want to work at all anymore. Since I figured it wasn't the oil pump I kept driving without the gauge reading. I just put a new sensor in it and it still doesn't work!!! When you turn the key on the gauge comes up to the "0" on the gauge and falls off when you turn the key off. I checked for codes and no codes, even with the "check engine" light on!!! Any ideas, ECM?, plug?, wiring harness?!!!!
