Archived No oil pressure?
Archived horn switch
Archived transmission stuck in fifth
I've lost the oil pressure reading on the dash guage, I've checked the oil level and it is normal, what gives.
Mike
try replacing the sender unit. This is a weak spot and they go out frequently. They are pricey, even at Cummins (but still about 1/2 the price of a Dodge one). As I recall, you need a 1 1/4 deep well to change it. Driver's side of the engine under the fuel filter housing.
Good luck,
-Vic
Oil Pressure Sending Unit.
You MIL is on right (Check Engine)? Mine went out at 60k. I think their around $60. Easy to change.
