Archived NO oil pressure
Archived My 95 died
Archived 2000 Ram Caliper Removal
The weather was around 100 deg. today, I had stopped to talk to a friend for about 5 minutes ,I started the truck and drove onto the highway and noticed no oil pressure I pulled over and opened the oil fill cap to see if oil was flowing over the rockers and it was. I shut it down for about 5 min. and restarted the truck And then the oil pressure went back to normal, Is this a glitch with the electronics ?
98. 5 Ram 3500 4x4 sport,Auto trans,3. 54's autometer,sport comp pyro,trans,boost,electric fuel press. w/snubber,warning light/chime. edge comp drag box,2nd VP-44 inj. pump,carter pusher pump,dual fltr. amsoil. Suncoast converter,valvebody,Built by Mike @ Inglewood Transmission,allum trans pan, Bilstien shocks,westin bars,push bar,custom 5" exhaust,BHAF, Silencer ring is where It's needed(at EX'S House).
I had that happen on a 96' scared the heck out of me, because I was on a long trip near the Utah/Colo. border. Luckily it was just the oil sender switch, it had developed a slight oil leak at the sender and shorted out the wiring.
I have had it happen to my 98 12v scared me for sure it was the oil pressure sending unilt on the side of the block under the injection pump then i ran a manual one off the top of the oil filter it now comes up alot quicker than the one in the dash ive since disconected the dash one.
