No Oil Pressure
12v gem on a lot
Sna Diego shops
Has anyone experinced loss oil pressure readings for just a couple of seconds (after engine has warmed up, never when cold) and you are stopped at a stop light. This only occurs occasionally. The chime goes off I look down and no oil pressure and then it comes right back to normal.
Could you include a signature so we can see what sort of animal you are herding around? You may have a sender or connector problem.
Yes
There were some post on that just a few days ago, go back and check last weeks threads I think you will find some Info. By the way welcome to the TDR.
Oil pressure
My truck would do this when the engine was hot and would drop just a tad below idle like when taking letting the clutch out to take off or something. I replaced the sender and it fixed the problem. It has not done it once since then.
