My buddy called asking for advice on his '01 with 38k miles. Background: Started the engine, everything normal, hooked up the trailer and drove approx 10 miles only to hear the check enging chime and zero oil pressure.
We cleaned the contacts from the oil pressure sending unit. Wiggled wires at ECM and PCM. All other guages read normal and engine sounds normal although affraid to drive it. Comp box and DD2's are only modifications.
Questions:
1. Is there a way to check the oil pressure sending unit?
2. Would a re-flash correct the situation?
Any suggestions and ideas greatly appreicated. We are stumped and don't feel the dealer will help now that the pump wire has been tapped. Thanks in advance!
Dave
Questions:
Dave
