Sorry, I've searched several time and I have to admit I still don't fully understand the seach engine here.
1995 RH Suncoast transmission. I've lost overdrive and noticed that cruise (I don't ever use) doesn't work. The flashing dash codes indicate, battery disconnected, short/open converter clutch circuit, and high/low voltage from transmission temp sensor. I forgot the nummers. transmission works fine in other gears AND lockup clutch works in normal postion and locks on demand via switch.
So I'm looking at transmission fluid/oil temp sensor and or speed sensor. Could the temp sensor affect the cruise? Is the speed sensor on the transmission? What's that thingy in the diff housing?
And parts numbers would be good. My guys are head scratching...
Thanks.
Thanks.
