No power to AC
Changed Batteries, now AC not working
Temperature sensitive door locks?
2006 3500, no codes, no power to the clutch or pressure switch with the ignition on or off. Fuses are ok, the AC light comes on and the blower blows. Low and high side pressures are ok with no freon leaks. Where else should I look? I have yet to run a jumper to the AC clutch. If I do, which wire on the plug gets 12V?
