Hey guys, I have a ‘99 Ram 2500. The blend door actuator that makes the blend door go from hot to cold and cold to hot isn’t working. I know they’re notorious for the plastic tips breaking off and rendering it useless, a common fix is replacing it with a metal tip.
1. So I pull it off ready to replace the plastic top...previous owner did this already, it already has the upgraded metal tip
2. I replaced the blower motor 40amp fuse and Relay under the hood, and 10amp fuse in the cab
3. I replaced the blower motor and blower motor resistor (figured it was unrelated but wouldn’t hurt as they Harry worked anyway)
4. I got a brand new OEM blend door actuator
5. After none of this worked, I ripped apart the dash and installed a new HVAC control panel with a new temperature switch
After all this I still have no power to the blend door actuator. I’ll plug it in, turn the temp gauge and the rotating piece on the actuator does absolutely nothing. I have it fully removed at the moment so I can rotate the blend door by hand as needed, but this is getting very old and I’m trying to fix it properly. Any ideas?
