No power to Glacier pump.
A2 Monitor
valair,centerforce,sbc,luk,spec,etc
I have a 2004. 5 no mods except Glacier fuel pump kit and fuel gauge. I do not seem to be getting power to the pump. I think I checked everything to make sure connections are good. The Bosch relay was a tiny bit loose. The inline fuse seems good. I did check and I do not here the pump running or fuel returning in the tank. I saw in an old post fuse 17 was for the lift pump but on mine it says viscous fan i think. I am not sure which fuse powers the lift pump relay or if it matters. Thanks for any help.
Thanks, Jason
I was able to find a truck to take out of town for the next couple days so I won't be able to check messages. But I happened to try Richard and talked to him, he will help me figure it out on Friday when I get back. I wonder how many other companies would talk to you at 10:00 or so. There's only a couple of things it could be but just no time to check. But that is some good customer service.
Jason
The relay is easy to check, just jump it with a paper clip and the pump should run.
I gotta give a round of applause to Richard also, I have had a couple fuel delivery problems and he has been right there to assist.
I am very happy with my glacier fuel system.
It appears it is the relay. I jumped it and the pump ran. Richard said to start there but I wanted to wait untill I got back since I didn't have time to wait for stores to open before leaving. Thanks for the help.
Jason
