Need help from electrical gurus. After installing and testing my new driver's side CIPA mirror, I apparently pinched the wire on the passenger side mirror when I tightened it down. When I selected the right mirror and tried to adjust it, the radio quit and I lost power to the mirrors. I can't find any blown fuses. The book says the mirrors share power with the door locks, but they are working. Any ideas where I lost power?
Just in-I checked out the fuses this morning in the dark before work. At lunch I reread the manual which took me to the Ignition Off Draw (IOD) fuse in the #17 fuse cavity. It had a yellow plastic gizmo on it that prevented it from being removed. I pulled the gizmo off, checked the fuse, and found it blown. The new CIPA mirrors and radio are up and running. The mirrors are way cool.
SteveT
'97 SLT Laramie Ext Cab LB 2 WD Auto, #5 plate, SPA Boost EGT, ATS transmission going in this weekend with report coming. Towing a 30 ft Cardinal.
SteveT
