Just the other day I was leaving work with a 20' car trailer and when I went to take off from a stop light the engine reved up and I went nowhere for about a good minute. Finally there was some drive power to the wheels and i was able to pull over. I then unhooked the trailer and was able to pull about ten feet forward before I lost drive power again. Luckily I was only a quarter mile away from the shop I work at.
Today I went about trying to figure out what is going on with my transmission. When I first started the truck after it had been sitting overnight I was able to drive it into the shop. However after it had been running for a a few minutes it lost all drive power through all the forward gears and reverse. It felt as if the transmission was not shifting into gear at all. I hooked it up to our scanner and there was a code for TCC circuit open or short but believe this code is a result of the mystery switch that my father in law installed when he owned this truck. I then proceeded to drop the pan to see if there was any thing going on internally. I found that the fluid had almost a burnt electrical smell but it did not appear to burnt or discolored. I then noticed a slight hum coming from the governor pressure solenoid and found it to be extremely hot, the key was in the run position at this time.
I'm wondering if the solenoid is not letting pressure build enough to shift it into gear. I'm going to buy a new governor solenoid tomorrow but would like to get some input before spending a hundred bucks at the dealer. Any help on the subject would be immensely appreciated as I make a lot of my wages hauling with this truck.
