Now we're starting to narrow it down.
Three things are fed by this fusible link.
1. Starter circuit- we know this is dead.
2. Fuses #1,2,3- Feeding the back up lamps and a whole bunch of ind lights in the IP: Wait to start, red brake light, water in fuel light (to name a few) Do these work?
3. Fuses #7,8,9,10- We know t-signals (fuse 9)and radio (fuse 8)don't work, How about the wipers (fuse 10)?
If all these are dead go check the fusible link. It can be tested by piercing the insulation just after the link ends (black lump on the wire) after the wire turns into a red (with NO tracer) 12 guage wire. With the test light grounded, it should light. If it does it isn't the problem and we need to look further "upstream". If no light, replace it with another fusible link wire (available at any parts store). Make sure it is soldered in and shrink tube or tape all connections. Also take and put RTV on any hole that you made with the test light.
Post any questions.
Wayne
