Working on my brother's 94. He just bought the truck. It has ~185k. I was asked to work on it because it was blowing white smoke. I assumed that this was caused by a weak lift pump and stock timing. I adjusted the timing to 16* and the smoke went away. While I was there I did some other modifications. Afc spring, ground the plate to a 100 (set in the middle), and put in 4k springs.
The truck starts fine idles fine and has some power 1700 to 2900. No smoke at all. Below 1700 it has nothing. You can put it in 5th and lug it and it will not go any faster? And again no smoke.
Could this be a weak lift pump causing this or is there something else that I am missing?
