I have an 01 with the 6 speed.
I use to be able to pull my 5er and atv trailer with the two atvs
(690 lbs each) behind that. Almost no problem.
It's a Big Tex trailer, a 50LE if I remember correctly so it's a big trailer.
This winter my injection pump went out. So Dodge put in a new one
and a new in tank lift pump.
I got it back and it was a real dog. No pulling power.
It pulls some, then just quits pulling. low boost7 to 10lbs and EGT about 800-900 maybe. Probably less.
I've had the fuel filter changed with the pumps were replaced.
To give you an idea of how it's running(with out the Juice with Attitude)
and before the aftermarket lift pump.
I was going to the Dodge dealer again.
It was snowing and icy. I touched the brakes to slow down
for they're driveway. Even with the anti lock brakes I slid past
the driveways! Both of them. So it's a little slick out.
I took the "Service Manager" for a ride, I get out of the street
and get going. I put it in 3rd(6 speed) and put it to the floor.
I'm thinking it should have almost leaped off the ground
or broke loose real bad or something.
Nope. It kind of just sat there and went down the road.
It just didn't pull. No boost pressure to speak off or anything,
Low EGT's. He said that is "Normal".
BS !!!!!!!!!!!!!!!!!
Anyway, he said the truck has no codes so there is nothing
wrong with it(real good mechanics).
HELP!
HELP!
