Archived No running lights
Archived Clutch Ripped Out...
Archived 04.5 cranks but won't start.
I am puzzeled,
I have head lights and fog lights, brake lights and cab marker lights, but I have no under hood lamp, rear fender, or tailgate lamps or no tail running lights.
I have changed out the head lamp switch and checked all fuses and still can not find the problem.
Thanks, TJ
All of the lights that are out (except your underhood lamp) go through a two wire connector. I can't tell you where the connector is located. You'll have to follow the wires from the rear running lights forward until you come to it. Either it is corroded or disconnected.
The underhood lamp works off fuse 12. That also ciontrols the glove box lamp, radio, and vanity lamps. If it isn't working, try the bulb. If it is OK, then go to the spring loaded switch and back to the junction box for continuity. Your switch may be stuck or broken.
