I have a 96 2500 4X4. The speedometer was working fine, I stopped at the store to get some groceries when I came out, started it up and took off down the road my speedo was no longer working. I checked the three wire connector on the transfer case, no corrosion, seems to be making a good connection. I have the Dodge service manual for my truck, from what I can get out of the manual the problem has to be isolated to four things, the speed sensor, wiring, the PCM or the speedo. I have not been able to find any diagnostic tests for the sensor in the transfer case. The manual refers to the Powertrain Control Manual for testing. Until now I was not aware that there was another manual? Has anyone had this problem before? Are there any tests I can run for diagnosis? One other thing that is probably important is the odometer and trip meter are also not working and my brake and ABS light come on intermittently although they are not presently on and did not come on when the speedo quit working. Thanks in advance for for any advice.
