So I recently tried to take a camping trip with my wife to go to the mountains but only made it 75 mi. and broke down at a truck stop. About 10 mi. from the truck stop the fuel light came on and when we pulled in it was very low on fuel. I was able to pull up to the pump with no running issues and shut the rig down, filled up with fuel and started up fine....as soon as I put it in gear it died and has not started since. I figured it was so low on fuel that maybe it boiled the fuel out of the lines due to being hot, so I cracked the lines at the injectors and did start getting lots of air out of the lines. I kept doing this until solid fuel came out but still no fire. Had a guy with a scan tool check for codes and nothing. I got towed back home and replaced the fuel filter, made sure the fuel bowl was clean and removed the bed and did a visual inspection of the tank to look at the fuel. Did not find anything suspect so far. I do have a Glacier Diesel Power mechanical lift pump mounted with the stock lift pump deleted. No other mod's done to the truck other than a Superchips Flashpaq Tuner. Anybody got any ideas before I throw a VP at it? 2000 Dodge Ram 2500 5.9L 2WD with Auto.
