Details here: TDR Privileges
It's possible to run the VP44 without an ECM (idle only) to see if it's an ECM or sensor problem. I think the ECM needs to see a crankshaft signal before it fires up the injectors.
i have not had a chance to work on it yet but tomorrow ill test the injectors for fuel
. thanks for the starting points. i replaced the injector pump about 4 years ago and have not had any less that 15lbs fuel since so i hope it's not that. i also replace the crankshaft sensor about a year ago.
