no start when cold... Help needed!!!!
Holiday Discount
Fuel and Maintence Log on Palm Device
:confused: My 03 ram is not starting when is under 30f. When it is plugged it will start when is plugged in for at list three hours. I replaced my heater relays. Replaced batterys and it is still the some problem. Any advice appriciated. Thanks
I assume you can hear the solenoids pull down for the grid heater, does your interior courtesy light dim when this happens??
Have you tried removing any of the aftermarket boxes? If not, I would start there and see if it helps. I know it is a long shot, but worth a try
This problem is happening on my other work truck and it has no boxs at this time. Did not have chance to get to that stage yet.
