If it were the crank sensor, your wait to start light probably dont work either. Unplug the crank sensor, if that is the problem the wait to start light will cycle. If you don't know, find the magnetic pickup on the harmonic balancer on the front of the engine, track the wires up to the plug next to the valve cover. If you have a 97 with a manual trans I have a PCM for sale cheap if you need it. If you have a 24 valve All of this might not apply.
