No tach and not charging
Tonight while out running some errands the tach started to jump around a bit at first. Well I thought okay I bet the connector just infront of the #1 valve cover has wiggled loose or something. Pulled over and checked it, everything was ok. Hopped back in the truck and took off again, no tach signal at all now. Weird. Checked the other gauges, everythings fine but the alt. gauge low (great here we go again I thought). Well I keep an eye on things as I finish up the errands and head home. In the 30 mile drive home the tach did flicker back on once. Alt. gauge came back up briefly then everything went dead again. In the drive home the battery (in the process of relocating them) was completely drained down to nothing. I pulled into the driveway with no headlights and everything that was electircal that I could shut off was off and it was dead.
The alt. is new so I don't think it's the problem. I would guess it's probably my engine RPM signal pickup is not working or the PCM took a dive ($$$$). Are their any test proceedures for the RPM signal pickup? What is the proper clearance for the sensor b/w the balancer? Are their any other things I need to test out?
TIA
Nathan
TIA
Nathan
