I have an 02 24V, I seem to be having problems with the accelerator/injection pump response, at times the truck will not pull any RPM goes flat, if I put it in neutral & stab the throttle a few times it will respond again. I notice it occurs more often when the truck is under a load. It hasn't flagged any trouble codes yet, so I'm not sure if its the Injection pump or the throttle pedal sensor. I do know it's not a lift pump issue.
I did notice the last time it happened & I stabbed the throttle, it puffed whiteish smoke out the pipe.
I have an Edge juice w/attitude & wondered if the controller could be malfunctioning.
I have also noticed lately when the truck is first started in the morning it seems to miss a little on occasion, kinda skips a beat at Idle, but doesn't when you drive away.
Any Ideas???
Any Ideas???
