I have a 2006 Mega cab with the 5. 9L and recently started having problems with my trailer lights. My running lights all work, and in the beginning only my right turn signal and brake worked. I checked my fuses and replace 2 of them. Now only my running lights work, it is this way on three different trailers and with my 7 pin and 4 pin.
I tested the lines to the plugs and the turn signal lines read about 11 volts all the time, even if the turn signal is on, when you plug the trailer in all volts disappear. Is there a module that runs the brakes and turn signals for just the towing? What else do I need to check?
This is my first Diesel and I am loving it!
