Having turn signals and brake lights is something you take for granted until you do not have them. I felt fortunate to make it home safely after towing a ways without them.
The trailer works when connected to my 06 dually and when connected to anything else, but not in my 03 dually. I figure the problem is in the truck. My plug at the back of the truck was a bit hammered so I replaced it. No luck . . . , still no turn signals or brake lights. I checked the power in the fuse box and all underneath and everything seems ok with just the test light, . . . sort of. On the turn signal wires the test light, lights, but dimly. Read a few posts about the possibility of the need for a reflash to up the amperage, but those posts seem to be tied to 06 and newer. Can't find any posts that mention doing this reflash on anything other than an 06. Can such a reflash be done to my 03, or is it a different kind of system?
