Thanks for the tip, unfortunately 2007 so TIPM controls. I'll trace the wire back from the compressor.If you’re truck is pre 2006 there is both a fuse and a relay in the PDC (fuse box)
That said it is fairly common on 3rd gen trucks for the wire that runs underneath the fan to control theAC clutch to come out of its creating clip and get damaged or even broken.
I suggest that you check under the truck for the wire first.
just my .02
I had this happen with my 2006. The TIPM will disconnect power to the A/C clutch if is senses to much current draw. As the A/C clutch wears it requires more current to engage the compressor. There are usually 2 option, replaced the compressor assembly or the the clutch only. I choose to replace the compressor since it was the original A/C compressor. I bought a kit from NAPA that included the compressor, orifice tube assembly and receiver dryer.
