Engine/Transmission (1994 - 1998) Noise in Drivetrain
2nd Gen Non-Engine/Transmission Stacks on a SB
It started out as sort of a chatter when decelerating, now it has become a squeal when accelerating or going up a small grade. Any ideas out there, the truck is a 5 speed.
Boyd
Did you check you intercooler boots? Is it low on power or have excessive smoke? Did it start after you performed work on the truck?
Boyd
I don't have any first hand experience to draw on, but I think it would be a good idea to check or have a shop ck the 5th / rev assm retaining nut. That is the main cause of failure in the 4500. If it is just starting to backoff, you may be able to aviod a major expense.
mechanic>>>David L. 94 2500,auto 2w/d,some light mods.
