Noise when under load
Low boost problem?
Installed Pacbrake !!!
I have had the opportunity to tow my 5th wheel three times in the last month. When getting on it (sorry didn’t notice the rpm) at certain speeds going up a grade I have noticed a slapping or noise like a piece of a tire was missing, really sounds like I had a flat. The noise comes from the passenger side.
Thanks. This site has helped in many ways. I read and heed and occasionally post. I have quit the other brand sites as too depressing.
Kimzy Bertalotto
2001. 5,3500 QC 4x4, HO/6spd,limited slip,BD,brake,60 gal Aero tank.
Wasn't there a thread a while ago where some folks reported the snorkle from the air box to the fender well making a similar "flapping" noise?
Dave D
2001. 5 QC, LB, 4x4, Auto, 3. 54, Everything but Leather, Bright Silver Metallic, ARE K Series, Diprocal EGT, Boost and transmission Temp in an Autometer Dash Pod, Westin CPS Platinum Step Bars - Black on Stainless
i took out my snorkle and even went under the truck the other day to identify a similar noise. the only thing that i could find was that my spare tire was dangling from its mount and needed to be tightened. i can still detect that strange sound at about 2600 extended rpms. i was wondering how long it would be before someone else noticed it, we have 2 2001. 5 hos and they both do it.
Some folks have had loose clamps on the outlet from the turbo to the charge air cooler and on the other side of the cooler where it goes to the intake. bg
White 99 3500, QC, 3:55, auto. most options except leather, Line-X bed liner, fiberglass running boards Rancho 9000s, bug shield and window vents, black vented 5th wheel tailgate, 110 gal. aux. fuel tank.
I did a search and the one I found described is as a howl.
It is interesting that it would be a flapping noise instead of a steady noise. The spare is tight. My co-pilot said it sounded like it was down by the transmission but you know how noise can travel.
I would say it happens above 2400rpms as I was in 4th gear pulling the grade at a pretty good pace.
Happy Camper,
Whoap, whoap, whoap... . about 4 whoaps a second until you back way off... coming from the passenger side... right?
That has happened to some of us before including myself. I too thought it was a piece of tire coming off. It went away when I replaced the air filter. We think it was making and breaking the seal in the air box. Like the it was trying to get sucked down into the turbo. Try replacing the air or swapping with a friends truck and I bet it'll go away.
Good Luck!
98. 5 2500 QC LB 4x4 5spd, white. BFG 285x75x16
Cummins 24v w/ TST PowerMAX w/EGT and Boost gauges on A-Pillar. VanAaken CPC. K&N In the factory air box. Stock Injectors, Stock Exhaust (Geno's Muffler Eliminator). Re-routed breather stink tube, 2WD-low kit, SnugTop, JJ Stainless Running boards, Tow Hooks, Bushwacker Street Flares, and a Cup Smoothie.
83,000 miles (1/10/01)
Yup. it's the air box, well actually the air filter trying not to get sucked into the intercooler. My Dodge boys service manager took a ride with me, and described the sound before we hit the road. I have an Amsoil filter, and have removed my intake air horn. It will make the darndest flapping sound after a hard acceleration, when it tries to relax and simultaneously stiffen. I really kind of enjoy it! I definitely enjoy it when I plant my right foot.
Ron
Yep, had the same thing last year going to May Madness while towing long grades. Bill Stockard had already been to Carson Dodge for his. They moved the heater hose to an outlet closer to the front of the engine. We only had a very slight noise after that.
I think there was a TSB for it, Cummins was to be working on a permanent cure for it.
Larry
Ram Rod
'01 3500 white quad cab sport 4x4 ETH DEE SLT+ 4:10s posi Pac brake combo gauge tow/camper pkg. 20k reese 5th hitch
35' holiday rambler 5th wheel
Thanks guys. The first time I heard the flap,flap I pulled off the highway and checked all the tires.
I kinda thought the airbox was the culprit as I was making it suck all the wind it could get and was asking for more.
That puppy sure can pull!!!!
