Noisy (electronic) Ram vs CB and Cell???
AFC Clicking We Will Go
Magnet to capture metal particles
Hello,
Trying to get to the bottom of a noise problem with my truck. A CB on this rig is out of the question, once the truck is running you'd think it was a gas truck with bad wires.....
Static on several CB installation attempts has been crazy. Grounding, etc etc no help.
Now I am fighting lousy Cellular phone service and starting to wonder if there is a connection to this noise as seen with the CB.
Anyone familiar with this who can tell me if I am barking up the wrong tree and/or what ideas I might try to isolate the noise?
No noise on the CB with the truck off. Cellular 'seems' better with the truck off, but hard to prove.
I wonder if my alternator might be the source, especially since I seem to be having premature battery failure on a truck with only 34K miles.
My alternator gauge is always well past the middle of the gauge, is that normal??
99' SB 4x4 : DDI's, HOT PE, SPA dual gauge, ESPAR, Line-X OTR, Ladder bars, AMSOIL, etc (GPS,Cell,CB,... . )
Green Monster
I would check Fritz's site for a TSB- I seem to recall Dodge adding a noise filter to the fuel pump... .
1997 4x4 CC 5spd, CPL1553 pump, Horton fan, Sport headlamps, Optima RedTops, 98 shift levers and console, RS5000 shocks, Toyo 235/85 tires... but going back to Michelin.
David_VT,
Is your radio working OK ? If it is try splicing into Radio's ground.
Sounds like electrical interference. Where? Not the spark plugs.
Does the 99 have the cable-less gas pedal?
Bill Thomas
Missouri Mule - 96 Wht 4X4 ST CC,5 spd, 3. 54, 8 ft bed, 1 ft high cheater boards.
99 Freightliner bl/wht FL60 ISB-5. 9 24v,215 hp,520 tq,6 spd, 3. 59 nsr,16 ft box, 19. 5 tires,Wt/gvw 11,000/23000
TSB 08-06-99 (Rev A. ) covered 98-00 trucks. Reportedly installing a RFI filter in series with the electric fuel pump motor will solve the interference.
1999 FLAME RED 2500 SLT, QC, 4X4 AT, 3. 54 AGATE LEATHER
Thx folks,
I missed that TSB. Another valuable set of inputs from the TDR team!!
I will hop over to Dave's site and check it out!!!
http://www.ecpe.vt.edu/~dfritz/technical/TSB00/08-18-00.htm
1997-2000 (AN) Dakota
1998-2001 (BR/BE) Ram Truck
[This message has been edited by David_VT (edited 01-13-2001). ]
I think this TSB pertains to gasoline rigs(fuel pump module). I have experienced the same problem and found it to be coming from the fuel injection pump. If you are picking up your power for the CB at the power dist. center, using shielded wire will remove most of the noise. I also have a filter but havenr installed it yet. This noise would be greatly enhanced by a fueling box. bg
White 99 3500, QC, 3:55, auto. most options except leather, Line-X bed liner, fiberglass running boards Rancho 9000s, bug shield and window vents, black vented 5th wheel tailgate, 100 gal. aux. fuel tank.
Your noise source is possibly your wiring for power and ground. First, your 12 volt power source lead should be run directly to the battery positive post. This is the cleanest source for power, as the battery is itself a noise filter. This lead should be 14 gauge or better. Second, you should ground the radio's power lead as close to the radio as possible, on a large major steel piece of the truck. Grounding of the radio is critical in this frequency range of radio. Do not splice or share any other ground with any device! You can actually radiate off the ground lead if you do! RF burn city!
Ron, KC7MME
'99 QC SLT 4X4, Forest Green, long box, camper/trailer pkg, 3. 55 axles, auto, CD/cassette, power seat, heated mirrors, HD xfer case, Two meter Radioshack ham transceiver (license KC7MME),Proud member of the vast right wing conspiracy!
'98 Arctic Cat 300 4X4 ATV
'00 Honda Recon ATV
'99 Grand Cherokee
NRA Life member
"Bible thumping" Rush Dittohead!
