i have a question about some noise in my transmission. the transmission is in a 97 with 180,000 miles. at around 160,000 miles the pilot bearing went out. no problem had a brand new clutch waiting to go in. while i had the transmission out I had a fully splind 5th gear shaft and a new input shaft and bearing put in. now when i release the clutch in neutral there is like a bad bearing noise. i had the transmission looked at and they didn't see anything that was bad. i know there is something bad in there i just need a clue what to look for. my question is what in there moves while turning in neutral and what should i look for? I also put a different clutch in to see if it was the clutch same noise.
