TDR RV’rs
Has anybody out there had any experience in replacing the “noisy” Ventline range vent 12v motor/fan assembly with a quieter one? My wife refuses to use to use the vent fan when cooking because it is to noisy for her sanity! Is there a “quiet” 12v unit available that anybody is aware of or has used to replace their “noisy” one with?
I contacted Ventline, they have an upgrade 2-speed “quiet” motor/fan assembly for about $20. 00 plus S&H. Upon questioning them it is the same noisy nylon fan/RPM on high speed. I. e. : same noise. They reduce the RPM 50% for low speed and viola! Less noise but also less suction and air flow.
I found a 110V squirrel cage blower from a wood burning stove that will fit with minor hood modifications.
But I am hesitant to use a 110v unit without installing a GFI. Then it would also require operating the generator or be hooked up to shore power just to run the range vent fan.
Thank you guys for your time and thoughts.
