Since this is the Offroading section... . maybe this is fair game
I have an 85 ford bronco that I swapped '86 F-250 gears under.
D60 rear (stout enough) and a "Light Duty" Twin Traction Beam Dana 44 with 8 lug hubs. I already blew the d44 spyder gears playing on a railroad gravel pile. It's strong, but I wonder if a D44 is enough.
I need a stright axle front to go on with my project... I did the axle swap and lift while I was in highschool... limited budget style.
What do you all recommend for an axle upgrade? It has 3. 55's right now.
I'm talking junkyard parts here. . nothing extravegant... .
I'm planning to cut the top off (body rot had claimed the cabs integretty anyway) with a full cage to the rear, rock slider bars and a set of 39 inch swampers with rock stomper bead locks.
I just need this axle worked out. If any of you all have anything I could look at for refference or info I would appreciate it. It's killing me not being able to wheel.
