non-wastegated exhaust housing
brake and abs light problems
M
running board brackets
If i would switch from my stock 12cm wastegated exhaust housing to a 14cm non-wastegated exhaust housing, what would i do with the line that goes from the rear of the afc housing to the wastegate accuator? Where should the gov. lever hit my camplate when it first touches? Is it easy to check and adjust it? What do i have to take apart so i can see the camplate and check the adjustment? Really happy with my 96 chummins turbo diesel!!!
turbo hsg
:Dgo to piersdiesel.com and you will find alot of info . the wastegate tube comes right off and you cap off the afc side. Oo.
