My '09 3500 QC, manual transmission, short wheel base truck averages 18 mpg at 65 mph. My (recently purchased) 07. 5 3500 C&C, regular cab, manual transmission averages 14 mpg under similar conditions (both unloaded). When I compare weight specifications on Dodge.com there is only about a 300# difference. The C&C has a flatbed on it that weighs (an estimated) 700# so the '07. 5 probably weighs a thousand pounds more than the '09. Does anyone think the extra weight can account for the mileage difference? I've looked at the differential housings to see if the '07. 5 has 4:10 gears instead of the 3:73 gears in the '09 but couldn't locate a tag. How do I determine gear ratio, short of counting revolutions of the axle vs the drive shaft?
Any input is appreciated.
