Originally posted by WDaniels
Are you saying on yours that when you get up to operating temperature(180-195) and you get in slow, stop and go traffic or stop lights that your brake will keep your water up to 180-195 even while idling at a complete stop?
My brake is closed at idle. The micro switch is on the back of the accerlator pedal.
WD
Yes, if I am going slow enough that my foot is completely off the pedal, or stopped and at idle, by turning the exhaust brake "on" my temperature will stay right up at 180 degrees (I have the 180 thermostat so I never hit 190 any more).
It will also warm up to 180 degrees in a few minutes from "cold" by turning on the exhaust brake and idling. Under the same conditions, starting with a cold engine but leaving the exhaust brake off, it doesn't matter how long I idle it, the temperature won't rise much above 140.
The only situation where it might cool would be if I am in very slow traffic where I'm using light throttle which turns off the brake, but not going fast enough to load the engine.
I'm assuming that when you say your brake is "closed" at idle, you mean the butterfly valve is closed, the exhaust is restricted, and is making that "whistling" sound?
If we're saying the same thing, then I'm thinking there would have to be a big difference between the PacBrake and the BD on how much restriction they provide at idle rpms.
