I have a 2015 RAM 2500 Laramie diesel/six speed automatic transmission with 5K miles on it. The transmission temp seems to run at around 237 degrees when I'm not towing and the outside temp is around 50 degrees. The middle of the temperature guage (computer generated graphic) is around 145 degrees, so it doesn't make sense to me that 235-240 would be normal. Had it into the shop and they said the fan clutch was seized up (5K miles) and replaced it. Is 235-240 "normal"? Is there any hardware like a thermostat that could be frozen closed? Thanks in advance for any info.
