I'm posting here because the truck is not currently working, if it belongs somewhere else please forgive me and feel free to move it.
2001. 5 4x4, 6sp, ~270,000 miles.
The truck is not charging the batteries. (I barely got home last night in the rain... using running lights only) Batteries were dead when I arrived and would not start the truck after turning it off. Now I've recharged them overnight it will start but not charge.
Symptoms when I lost the voltage gauge were this:
Driving at night, the check engine gauges light comes on, and the voltage gauge is slowing dropping to around 8 volts then dropped totally to zero. I turned the key off and then on and the gauge came back... but within a minute slowly back down to 8V again, the check gauges light comes on and the voltage gauge drops to zero. The other gauges: speed/tach/temp/etc. are all still working.
I've done a bit of reading here today and took the alternator to NAPA & Autozone and had it tested... it failed both times. I bought an Autolight Pro-tech remanufactured alternator with a lifetime warranty (any idea as to the quality of these?) and then had it tested... well two of them failed also. Their explaination of why is that because this alternator is externally regulated it is impossible to check on their machine. (what do you think about that?) So I went ahead and brought my core back home.
Before pulling the alternator, I started the truck after pulling the alternator leads and the small plug has two pins... . checking voltage between them and ground have less than one volt on one and a variable reading on the other (4V through 9V). The wire that goes over the large stud produced nearly 13V (I assume that that is connected to the (+) side of the battery?
I know that my throttle positioning gadget (variable resistor, or sensor forget what it's called) is wearing out... I've adjusted it once about 30k ago as per the instructions here on TDR. I recently two weeks ago lost all gauges and power (truck still idled) and after turned off sitting a bit it worked again. Heavy throttle application will produce a missing sensation (I thought maybe there was water at first... but now am guessing the throttle positioning sensor needs replaced.
That is unless it's the PCM. (which also houses the external voltage regulator right?)
I'm reluctant to simply install the new alternator for fear it may be something else and money is a bit tight right now (I've got to do a wheel bearing and brakes).
So what do you think? Is there a way to rule out the PCM? If I could rule out the PCM I'd just install the new alternator... . a customer at Schucks where I got it was very down on schucks quality (and the new one DID fail the test, that is it failed IF you can test it reliably on a machine out of the truck) ... . So if I'm going to slip a new alternator in might rather find a better quality unit...
I need some guidance on how to proceed please.
