Hello,
My truck is not cranking for some days.
Since I'm working only minutes from home now, I was suspected my batteries were weak but with the boost pack nothing happened.
I had to tow the truck home and performed some tests :
- batteries fully charged : nothing
- since my starter was showing some bad symptoms and has more than 15 years, I changed it. Nothing.
- positive terminal of the starter to positive battery terminal with jumper cable and key to start : nothing, so I assume the cable is ok.
- starter signal terminal to battery positive : cranking (starter ok, so relay or wiring issue ?)
- did take out the starter relay in the fuse box under the hood (driver side). using a voltmeter I read battery voltage between pin 85 (ground) and pin 86 (12,5v when key in start position)
- I replace the starter relay with an other one but nothing. To be sure, I jumped the relay with a wire in pin 30 and 87. The fuel solenoid is acting but no crank.
- I jumped the Park/Neutral safety switch (center pin of the plug to ground) Nothing.
At that point, I assume I've missed something...
Your inputs will be welcomed.
