I have a 2008 2500 quad cab 4X4 and I am the original owner. Until recently the truck has always run a just above 190-195 Deg. In the last few months it has begun to creep upward towards the 200 Deg. mark. It is at the 105K point and I am about to do a service on the cooling system. Replace coolant , Water pump,Thermostat , Rad & Heater hoses plus the Idler,and tension pulleys and of course belt. I'm hoping this will return the temp to its previous range. I'm also going to add a deep sump pan to the transmission which I hope will help with the cumulative heat load.
Is there anything else I should be attending to while I have the front of the engine accessable?
Thanks
Thanks
