"Mad Max"
So this morning the ole girl wouldn't start. Cranked just fine but no fire. Here's the intel:
Yesterday morning was one of the coldest in recent memory, -4 degrees. Go out at 4 am to start/warm up for work; start and ran (unhappily) for few seconds then chugged off. Re-started, then ran unhapilly. Wouldn't idle at normal rpm for a few minutes, but didn't stall out. Bitter, bitter cold. Everything was frozen. Got to work no problem, even had some heat and ran fine after few minutes.
After work, started normally, ran perfect all the way home, however the LOW FUEL light did blink on a couple times during decelleration and some turning, tho the light was not on when I shut if off for the day nor was it on this morning. Was going to fuel up on the way into work today.
Today (around 11:30 am) was no where near as cold as yesterday, but it would crank just fine... but not a single hint of firing up. Compared to yesterday... it should have started today.
It acts just like there is no fuel at all.
Fuel does have anti-gel in it.
So, I'm thinking either the fuel was gelled or is just low enough for some fuel issue, or, the fuel solenoid isn't getting power.
Tomorrow I will check the 12v power to the soleniod. Either side should show 12v power with the key at 'run' correct? If not, could be a bad solenoid, ja?
If both sides have good 12v power I will get 5 gallons of #2 and 'tank up' a bit, then prime the lift pump, and check the injectors.
Any other thoughts?
- M2
Any other thoughts?
- M2
