Tony T. said:
I have the X-Monitor on my truck an unloaded temps this time of year are running around 140*F to 145*F. I had the X-Monitor installed back around last of March when weather was cooler an the temps then was around 130*F. Here back first of August we took our TT on a camping trip, first trip since I had gauges installed an I was surprized that with pulling my TT around 6000# that trans temp never got over 160*F even while backing,(outside temps 97*F). I thought they would be up to around 175*F or 180*F. According to the 03 Owners Manual their saying that (normal full mark) "hot" fluid should be 180*F that's after vehicle has been driven at least 15 miles, an "warm" fluid around 125*F(running a short distance I take it, an fluid should be between the two holes on the stick ). All this is in the manual on how to check your trans fluid procedure. Still have the stock pan myself. So go figure on the accuracy of location of probe, I've questioned mine also especially when I towed with it. I would like to know dead on for sure reading.
