Engine/Transmission (1998.5 - 2002) NOT tapping wire
Engine/Transmission (1998.5 - 2002) by pass filter
Im tired of replacing VPs out of my own pocket. Yes yes i know, im my own waranty station.
As the sig says, i have an EZ stacked with a PM3 Comp. Is there any option to add as much fuel as the TST without tapping?
I was kinda hoping with all the recent software flashing, someone had come up with a way to make the ECM overfuel like a tapped wire.
I guess it's the luck of the draw. Mines been tapped for over 50,000 miles and I have had no problems. The lift pump was replaced under warranty right before I got the truck at around 30,000 miles. Mines been tapped since then and I added an Airdog to keep the fuel comming, no vp44 problems (knock on wood)
You can use a stealth cover from Blue chip to make your connection. Some guys don't like them, but I've had mine on for 40k with no issues. This way you don't have to splice into the wire.
