Now Leaking Power Steering
Clutch topic, different question
Stock Boost PSI??
has ne one had the power steering leak? i cant tell where it is leaking i did not get a good look at it this morning. man i hate leaks. i am going to keep am eye on it to see what happens.
Mine was leaking out of the top of the power steering gear box. Its hard to see. There are four bolts that hold the cap on. The only way I could get it tight was to buy a LONG extension and get at it from the top.
Check it out.
Dennis
Ditto what Partyat33 said. Just a couple weeks ago I posted the same question. Was told to check the cap on the gearbox and sure enough 3 of the four bolts holding that cap on were finger loose. Seems to have cleared up so far.
