Well, I finally got the head off today, just as I suspected, #3 piston is melted and galled. The pump was set at stock, stock turbo, stock everything... maybe a piston cooling nozzle stopped up. . what do you guys think? I have no idea why the #3 piston melted! It has scored the #3 cylinder walls somewhat. I haven't checked the head for warpage or cracks, but I would'nt be surprised if it wasn't also damaged. Now comes decision time. Which way do I go about repairing/replacing this engine?
Do I:
A. Take the block out, strip it, bore the one damaged cylinder and install the thin wall repair sleeve? I know this will involve stripping the engine completely and buying all new parts to "build " the engine. This way I will know what I've got when finished, but it will take longer and involve running around after various parts, etc.
B. Go for the quick fix. Buy a used complete engine out of a salvage yard? I have found some for around $2k complete from pump to turbo. Most need a new oil pan from damage in the various wrecks these trucks were involved in. I have found a 96' and a 97' currently that have around 100k miles. These prices were straight out- no core. Probably go ahead and pull the timing cover and tab the KDP before the install.
C. Go to Cummins and buy either as complete of a long block as possible to make the repair. Do they bore and sleeve their reman blocks and use standard size pistons? Or do they bore the block and just install oversize pistons?
D. Go to Cummins and just buy a reman short block to make the repair. Also same questions as in C above.
We will be using this truck as a work truck and it probably will not be bombed. If it is it will be only very slightly-- just for load pulling purposes only, if at all. The truck has a very good body, but it does have 213k miles (+-) and has always been used as a service truck.
Does anybody have the part numbers for any of the items in the repairs I have proposed? Namely:
1 The service cylinder repair sleeve?
2 The reman short block part #?
3 The reman long block part #?
4 Any other part #'s that you think I need to consider or
other parts that I may need?
All feedback appreciated on this decision I will be making.
Do I:
